Ok. First, thanks to all of you for your posts. I just switch a motor and replaced it (johnson) to a yamaha c60tlry (2000; 60hp) I had to gut from ignition to motor but now have her running and everything works, but one thing
Where I insert the cables through the rubber boot to the engine, what is secret to keeping them from shifting in and out as I move the controler? Is there a mount they should be secured to? If so, what is it cause I only have the boot, wires through it, a cap on top and then pins to secure the cable joints to the pegs.
Can anyone help with this? Maybe a installation picture....
