Does someone have a diagram or can describe to me the water flow path of a 06' 115 TJR it is a F115 motor with a jet unit. Where does the exterior flushing device enter that path. Thanks in advance
Water Flow Path
The service manual doesn't list a flow chart for cooling system. Are you having an overheat problem?
I know it does not list the flow path, and no I am not having overheating problems. I was just curious as to how it entered the engine. I just was tring to figure out how the water got past the thermostat. Does it enter the bcok from the bottom first or from the top by the thermostat. Thanks for looking
The water pump is in lower unit and it pumps water to engine through a tube that enters bottom of engine block.
Â
