What size prop? & other tech questions???
  • What size prop? & other tech questions???
    Just purchased a 1992 Ranger 365 with a Yamaha ProV 150!
    Questions:
    What size prop should I be running on this? 3 or 4 blade?
    What should the water pressure be at idle and at 5600 rpm?
    Thanks for all your help!
    Not sure which pitch prop would be best for you, generally 3 blades give more top speed and 4 blades give better hole shot.
    Should have mininum 11 psi water pressure at wide open throttle and 0 psi at idle.
