703 controls
  • 703 controls
    I have just installed a 92 70hp yamaha and was wondering if the buzzer in the 703 control should come on when the key is first turned on to check if it is operational. Thanks
    I do not think it will test itself, but it is easy to test, just pull the pink wire off the temp switch and ground it with the key in the on position and it should sound off.
