2003 F115 wiring
  • 2003 F115 wiring
    What do the two pink wires in a 4 pin connector on the Starboard side of the F115 go to? If they are oil and temp warning circuits, which one attaches to which wire on what would be the green w/ red tracer and green w/ white tracer on the Yamaha Multifunction Tachometer harness. My wiring harness between the motor and tachometer does not match up to anything.. . .
    The trim/oil harness you installed for gauges should have had 2 off white colored square connectors on each end of harness, if the one you installed only has 1 connector on each end then you have the wrong harness and tach for your motor.
    1994-2004 motors uses
    6Y5-8350T-82-00 Multifunction tach
    68F-82553-90-00 Trim/oil harness
