I have a 1990 200 hp Precision Blend with Yamaha gauges and am not getting a speed reading. I want to make sure the pitot inlet (and tube) on the lower unit is not clogged. I thought I'd just drop the lower unit and run a wire through the top side and hopefully out the pitot inlet. Anyone know what is in there, if anything? I don't want to damage anything.
1990 200 hp pitot system
Originally posted by BQUICK View PostMight try blowing out with air first......
Originally posted by BQUICK View PostJust the tubing and a connector. Might blow apart the connector but I doubt it. Apply air and have someone check for bubbles at the lower unit. Also tilt motor and take a paperclip and stick it in the hole......
ÂÂÂÂ
