1998 ox66 225 runs rough at low rpms
  • 1998 ox66 225 runs rough at low rpms
    I have an 225 ox66 .Starts up perfect.runs great but runs rough at low rpms as soon as it goes to six cylinders(1900 rpms) smooth as silk.
    Possible need to do synchronization and linkage adjustment, maybe a new set of plugs.
      jim
      I have had the same problem for some time. I have a 1997 250. If I ***** all day I have to change the plugs. Runs great at cruise but it don't want to idle at the dock. When I put in new plugs it runs perfect until I ***** for awhile again. I cannot fix that problem. I have done a decarbon, new fuel pumps, adjusted the oil mix, changed filters, and replaced the O2 sensor. I use Yamaha ring free, but if I ***** for 3 or 4 hours it carbons up the plugs and I have to change them. I hope someone has another idea that we can try. Good luck!
        I was told by mechanics who have the motor thats how they run.I synchronized the throttle body linkage and the oil pump linkage. Oil pump helped the most. New pugs helped . Cleaned carbon from 02 sensor . I have the test lights for the motor ,all was good . Replaced thermostats . Just cant seem to smooth it out at low rpms . Txs
          Guys I'm not buying that. There are lot of guys that ***** these motors with no problems, bigfish you reading this??
            Those engines only run on 4 cylinders to about 1200 rpm's thats why sync and oil pump link arm adjustment is important. Jim you might try new thermostats to see if helps with plug fouling.
