analog tachometer options
  • analog tachometer options
    Hi all, new to the forum and already have found it a wealth of information. I have a 2004 F90TLRC w/ 704 controls. Boat is set up w/ 4 analog gauges: fuel, trim, speed, and tach. Currently the tach and the trim are not working correctly. The tach gauge is a Faria. Interested in replacing with another analog gauge and am interested in what options exist. Can I buy a teleflex or other aftermarket gauge and install w/ the current wiring? If so is there a new/separate wiring harness needed? I like the aesthetics of the current setup, and am trying not to break the bank (the boat cost enough already!). Thanks, DAVE
    Yes any of the aftermarket gauges will work as long as it's for outboard engines, same wiring should work.
      thanks for the info... Anyone have any recommendations on a quality aftermarket analog gauges? Teleflex Lido, Faria etc?
