I came home to see my motor in the down position and battery drained. I disconnected the motor and recharged the battery and as soon as I connected the motor again the trim motor is running in the down postion and will not come up when I press the up trim button. When I do press the up button it stops the trim motor and restarts again when i let go. Any suggestions?
power trim in continuous down position
Originally posted by jb123 View Postdisconnect each trim switch to see if one is bad.
disconnect blu and grn @ relay , apply 12v and ground to each ensuring motor is working right then sounds like your relay is stuck closed or you have corroded/pinched wires leading to switches.
Originally posted by jb123 View Postdisconnect blu and grn @ relay , apply 12v and ground to each ensuring motor is working right then sounds like your relay is stuck closed or you have corroded/pinched wires leading to switches.
Originally posted by jb123 View Postyou never mentioned your motor.
Number 10 and 11 in this diagram are the trim relays Yamaha Outboard Parts 1993 115TLRR ELECTRIC PARTS 2 Diagram
ÂÂÂÂÂÂÂ
