1900 2-Stroke intermittent spark on 2
  • 1900 2-Stroke intermittent spark on 2
    I have two 200 HP 1990EXTD two strokes. On one engine the plug is always clean (brand new clean) when all other plugs have signs of use. The motors run good, but cylinder number two has me concerned. Here's a list of things done:
    Replace Plug/Coil Wire with new
    Swapped new plug/coil wire with known working one
    swapped CDI Units on both engines
    Checked carb jet for proper settings (1 1/2 turns back)
    All resulted in in random flashes on timing light and no visual use on plug. All other plugs and the entire other engine have steady flashing.
    What should I try and/or check next?
    Thanks all,
    Frank
    PS the engine runs good, starts right up, plenty of power (40 MPH last weekend crossing the bar). But, it can't be right. THe timing light will completely stop for 5-6 seconds, then have normal flashes -Very Random. All others, nice and steady.
    Frank
    25 Grady White Sailfish
    Run ignition test on pulsor coils and CDI output voltage.
      re Run ignition test on pulsor coils and CDI output
      I swapped CDI units from other engine (which is working) and same results (random sparks on No. 2). Also, checked compression on all six today. They all read 120, +/- 2 . And, did another carb cleaning (completely romoved jet screw and mixing chamber... Everything seems clean.
      I'll look at the manual for the pulsor coils and Ignition test. Again, swapped CDI's and Spark/Coil wires with known good engine. And still random sparks...
      Thanks for the help.... I'll keep reading and researching...
      Frank
      Frank
        update found problem
        after spending a very long day (about 10 hours), with two engines I swapped parts until I narrowed it down. Change each component one by one (plugs, plug wires/coil, cdi, pulser coil, charg coil, fly wheel, everything.) And still had an intermittent spark that at one point stopped sparking at all.
        What I found to be the problem was a small harness between the CDI harness and the Pulser Coil Harnes. It had one wire in the connector that was coming out as it was connected. A little super glue and problem solved.
        However, I don't see that harness in the parts section. It's about 6 inches long, about 7 wires going in/out, with one wire going to a ground.
        The connection from the CDI to the Pulser connect, is there any problem running the engine without the middle harness peace?
        Thanks all,
        frank
        Frank
