1985 Yamaha V6 Special not firing on all cylinders
  • 1985 Yamaha V6 Special not firing on all cylinders
    I have a 1985 Yamaha V6 Special which I have done a lot of work on and still cannot get it to fire on all cylinders. It had a lot of corrosion on it so I have cleaned it up. The carbs are cleaned. Changed the spark plugs. Put on a new coil. Compression is good. Changed the stator. When I changed the stator it actually ran well for a minute then went back to not firing on all cylinders. ANY help on where to look next would be greatly appreciated.
    Test all ignition componets per service manual. Make sure all ground wire connections are good.
