Hi, My father and I have a 9.9 Yamaha engine "kicker" working alongside a Yamy 90 HP main engine mounted on an 18 foot welded aluminum boat The kicker sees limited use, and is only used when fishing and *****ing for salmon. What I have noticed is the anode on the leg of the engine is still like new, and the casing of the leg is starting to develope quite deep cancer mainly limited to one particular area of the leg. It is quite ugly to look at. This damage is quite clearly electrolysis to my eye (Professional Marine Engineer). The main engine is in good condition and the anodes on it require regular replacement particularly the one on the bracket where the 90hp attaches to the transom. These engines are mounted on a welded aluminum boat (Silver Streak) and are also isolated from the battery with an isolation switch. This kicker is a pull start and complete runs on its own (no battery, charger, manual control, etc..) The anode on the leg of the kicker is factory, and has been there since the engine was purchased in 92-93. Has anyone else experienced this problem, and what did they or Yamaha do as a result. I suspect the contact of the anode is not good?! Any ideas from this forum would be appreciated. It has been this way since new, and only in the last couple of years has developed this hole in the casing in way of the leg. I am concerned that I will need to clean it out and fill with expoxy product of some kind. The engine is excellent and runs forever on a gallon of gas and we quite like it, however this may certainly shorten its useful life compared to others.
Help
Help
