Hi any input here will be much appreciated!
My one motor is only revving up to 3500 RPM and I have checked the usual things and replaced the racor fuel filters. I did a visual check on the filter on the outboard but did not see anything suspicious.
Before I take the carbs apart what else can I check? Motors are "new" with less than 50hrs, although they are '99 models. They have been standing a while.
I noticed this weekend at about 2000 RPM, the revs tend to be uneven between 2300 and 1900 RPM, but at idling and open throttle the revs are constant. Took the spark plugs out after flushing (should maybe try again after an open throttle run) and they were all a bit black and oily. none were particularly worse than the rest. The gaps seemed a bit big - did not measure, but does anyone know what the gaps should be?
Sorry for the long-winded blurb, but hopefully I can get some help with this!
thanks and regards
Will
thanks and regards
Will
