con*****er or oil level sensor
  • con*****er or oil level sensor
    115HP ETLK, oil keeps pumping from sub unit overflowing main unit when key is on. Removed oil level sensor and turning upside down, still pumps,low level alarm sounded when pulled out. How can I test to see which is bad?
    You can ground the White wire on eng. oil tank sensor with ign key on and the oil transfer pump should shut off, if it does you have a bad sensor, if it does not then the oil module is bad
