I thought I would just start another thread here instead. i now have added fluid to my tilt/trim, but I need to bleed the system. Right now it will only go maybe halfway up under power. I used an overhead hoist to pick up the engine, then I added the fluid, put the cap back on, set it down, ran the trim button, picked it back up wtih the hoist, added more fluid, ect. i did this about 5 times. Now when I take the fill bolt out, some bubbly fluid comes out, so i figure I need to bleed the system of air and add more fluid since the motor only goes halfway up. Anyone have a schematic showing what lines to bleed and procedure for it? I do not have a manuel for this engine.
Keegan
Keegan
