I have a 85 115 yamaha which has been a awesome motor till this spring. Starts fine, idles fine, and runs good to half throttle. Now when i punch it, it doggs down to a crawl. Fuel bulb stays hard all the time. Recently changed plugs. I cleaned fuel lines out, fuel filter, and replaced the fuel pump today. Diaphram on old pump looked fine. Recently in the shop before this problem and mechanic said everything a ok, including compression. My next guess would be clogged jets. Can i access the jets without tearing the carbuerators apart? Or any other suggestions out there? Thanks.
1985 16 1/2 skeeter with 115 yami, jackplate, stainless steel prop. top speed 65mph. Now thats mowing in a 16ft'er.
