VX150TLRY PEE Hole Question...
  • VX150TLRY PEE Hole Question...
    Dumb Question...
    Where Is The Pee hole For My 150 VMAX OX66 2-Stroke
    I don't think it's shooting water out like it's suppose to or I'm sure i could find it...
    Should it pee at an idle?
    The motor has a jet pump on it if that helps...
    Also can you run these pumps out of the water like in a barrel or muffs?
    Thanks for all the help...New to this...
    It is on the right rear side of lower engine cowling, you will the small hose connected to it if remoce top cowling. No jet drives are hard to run in a barrel they just blow all water out of barrel.
