What is the best external fuel filter for 90 yamaha outboard ? I'd like to hook one up between gas tank and motor ? Do i really need to have one ?
A fuel/water seperator is an absolute must for good dependable motor performance. the Yamaha 10 micron units have to be great, just a bit expensive. I use the Walmart fuel/water seperator($27), easy to install, works like a charm. new Walmart filter cartridges about $7, I just unscrew mine, dump the water/trash and re-install it. this works fine on my boat with above board, external fuel tanks that I can dump and clean easily. with under deck built in tanks maybe you need a new cartridge more often, depending on how much water/junk is in your system. Good Luck!
I installed the Yamaha fuel/water separator when my F60 was new and have been very pleased with performance. I just replace the spin on filter every 100 hours. Check with boats.net for price and size for your 90. There may be cheaper filters, but I figure it's cheap insurance knowing I have the filter designed and sold by Yamaha. You bought the best outboard, so spring for the best filter...just my opinion.
