T9.9 problems
  • T9.9 problems
    I thought my problems were solved when I reconfigured my fuel delivery
    system with a 10 micron filter and new hoses. Generally, the engine is
    running better with a tank of fresh gas.
    However, after motoring on Lake Michigan for about an hour and later trying to restart it, the engine balked at starting. When it finally did start it died with a few coughs. It would then start, but die when put into gear. It took about 5 starts for it finally to run in gear. It ran fine for the remaining half hour to bring the boat back to the slip. I have no idea what caused this
    problem, and hope it will not get worse. Usually, the engine is
    reluctant to run in gear until it has warmed up a bit, but I can
    somewhat accept that.
    The other problem is a hesitation in the throttle when trying to accelerate
    from idle. I have to turn the throttle about 30 degrees before the engine
    picks up speed. My first thought was something about the high speed
    carb jet, but it runs fine when it is over this 'hump'. I inspected the
    throttle linkages, and saw no slack anywhere. What can be causing this
    hessitation?
    If it has old style fuel pump on it it may be vapor locking, if fuel pump only has 2 hoses connected to it then replace fuel pump with water cooled version.
      T9.9 problems
      Thanks for the reply.
      Although this engine is a 2002 model, it has not been used very much, maybe
      15 hours per season. It is an auxiliary for a sailboat, so we mainly use it for
      going in and out of the harbor. I don't know offhand what kind of fuel pump
      is on it, but your suggestion sounds like major surgery. I hope the solution
      is simpler.
      I would also like some advice about this throttle lag, which has plagued me
      for many years. I think the linkages are tight, so what else can cause this
      behavior?
      Sherwin
        May need carb cleaned and new diaphram in accelerator pump in bowl of carb.
