impeller blades missing 70hp
  • impeller blades missing 70hp
    due to high temp alarm after 20minutes *****ing speed, I changed impeller only to find 3 blades missing, any advice to where the rubber pieces would end up. Do you know how I can get a manual real quick in Australia ? yam70beto 8h3 L 478184 THANKYOU
    Remove the water intake screens on lower unit and see if any in there, remove thermostat and back flush with water hose with lower unit off while holding a bucket under water tube at bottom of motor and hopefully you can get it all.
      john,
      Go to yamahapubs.com and see if they can ship you a manual to Australia.
      Good luck,
      Ken K
