I am looking for a part number source where I can find the number for a broken cast piece from a 1988 Yamaha 40 ELG (Electric tiller). The places I have looked do not show this casting. The piece is the casting that is bolted to the steering bracket (6H4-42510-02-EK) and to which the shift handle, dead man switch, the key ignition and the throttle handle are bolted. The on line parts diagrams I have found only show the hook steering piece (6H4-48511-51-EK), or a bracket (6H4-42121-02-5B) but not the casting I need. This casting is ~8 inches long and 3 inches wide with provisions for the above mentioned throttle, shifter, ignition and dead mans switch.
This motor has a steering guide (689-61350-02-00) that uses friction to resist turning the tiller, with the friction end in the motor hinge and the other end attached to a small tab of the above mentioned casting. There are provisions to put this steering guide on either the port or star side, and both port and star tabs are broken.
If anyone has an older printed parts list it may be shown, but I haven't found it in several on line sources. Thanks so much for any help.
Roger
Roger
