I understand the injectors are fairly easy to remove from the fuel rail. I want replace the injectors and send the ones that are clogged off for cleaning. That way, I will have clean spares. Problem is, I have no idea where the fuel rail is located.
My next goal is to clean out the VST filter. Anybody have a step by step method to get to this filter.
Thank you,
Roy
Thank you,
Roy
