I used a 6YR-W0035-F0-00 MULTI FUNCTION TACHOMETER AND SPEEDOMETER KIT on a 2005 motor. Everything works but the oil and water modes. I can't figure out where to connect the pink and orange wires. There is no matching plug as there was on my 2001 f115.
2005 F115 gauges
Also, is the buzzer supposed to sound when the key is turned to on? Also, when turned to on what is supposed to display on the tach? I show a bar above the oil and the thermometer symbols and a picture of an engine? AND....when the engine is running and I press mode on the tach it only switches between blank and hours display, are there more displays I should be seeing?
