PLEASE HELP. I have a year 2000 (MANUFACTURED jUNE 2000) 9.9. yAMAHA, MODEL T9.9ELHZ. I bought a 703 remote control unit, labeled "PUSH" and with a SEVEN PIN cable. WHat parts or kits will hook it all up? And where is the SEVEn pin cable located on the motor??? I hope what I have so far will all work together. Where can I find a diagram on how to hook it all up??? Thanks much. bob
2000 9.9 yamaha remote conversion help
You will need a pull to open control box either use 703-48230-12-00 control box or convert your box by changing throttle arm to pull to open, part number 703-48261-11-00. It's not an easy task to change it out.
You would also need
6G8-48501-03-00 Remote conversion kit
6G8-48511-10-00 Steering hook
(2) 97095-06016-00 bolts
(2) 92995-06600-00 washers
(2) MAR-CABLE-xx-SC(replaced xx with length needed) Throttle/Shift Cable
6G8-82590-00-00 7-Pin engine wire harness
6G8-61350-00-00 Steering Arm
Thanks, boat.net and more questions
Thanks for the help Boats.net. This is for a sailboat, so do I need the steering hook and steering arm if the Yamaha is "fixed position" and I use the sailboat rudder for steering? (something available to "lock" the motor into position?) Also, what are the bolts and washers for? I assume the 7-pin wiring harness plugs into (or wires into) the motor somewhere (does it come with instructions)? Thanks again. bob
Â
