Controls for 2004 Yahama 40hp 4st remote
  • Controls for 2004 Yahama 40hp 4st remote
    Hi there
    I just bought used a 40hp 4 stroke and need controls for a RIB with a console
    Can the 703 be mounted on either side or is it on the left side of the console only?
    Do I need a push or pull verison of the 703?
    If I use a 704 binnacle what do I need to conver the 7 pin on the 704 to the 10 pin on the motor and how do I install a key start?
    Can I use the flush mount 6x3... control - does that have a 10 pin connector
    thanks in advance for the help
    You can use 703-48207-17-10 side mount control, it will mount on either side of console.
    The 704 binnacle or the flush mount control boxes requires installation of switch panel and main harness.
    704-82570-08-00 switch panel
    6X3-8258A-00-00 16ft 10 pin main harness
      many thanks
      much appreciated
