I have recently purchased a used motor without controls, wire harnesses, ect. I have purchased a new 703 con*****er, throttle, and shift cables. I need to know what tach and additional harnesses I will need. Trim and oil sensor harnesses from engine to con*****er seem to be missing.
90ETLK Wire Harness
Trim/Oil harness for the older motors are no longer available, you can use an analog tach without oil level lights by using 6Y5-83553-N0-00 gauge harness connected to the yellow, green, red, and black wires on 703 control box.
Thanks for the quick response.
Could I use one of the newer digital tachs and harness on this application? Or maybe the Yamaha Pro series tach with trim and oil level. The only wires missing are the trim angle and oil indicator from engine to tach / con*****er.
Thanks for your help.
Houndman99
Seems I found a post from Boats.net to bighause001 on 05/21/09 that answers my question on this post.
Again, Thanks
ÂÂÂÂÂÂÂÂÂÂ
