I have repowered from a early90s 90etld to a late 90's f100
The old setup had an analogue tach with oil level and a second trim gauge.
New motor came with digital speed, temp, time and digital rpm, oil, and trim.
(older models with 4-6-8-12 dial on the back)
I am having great difficulty locating wiring schematics to make the changeover.
I plan to keep the existing 703 control box. Current 10 pin harness seems to work well.
Here is a schematic of what I currently have. It all seems complicated by a remote control unit marked 6H1 Stanley BV015-14170A
Tack/ Oil Guage
Blu
Bl backlight
B to control unit
G to control unit
Y to control unit
B to control unit
Y to 703
B to 703
G to 703
Trim tilt guage
P to engine
O to engine
B to engine
Y to engine
6H1 Module
y to 703
B to 703
P to 703
GR to engine where it connects to pink on rear block sensor (temp?) and oil reservoir
G to engine where it connect to oil reservoir
GR to Tack red
G
Y to tack B
YR
I can only find 2 harnesses on the newer F100 – a square female connector with P B O and G (which is a butt connector) and a square with PB and PW
Clear as color coded mud?
Ideally I can use the same wire runs and get adapters to go from the existing butt connectors to the new square connectors.
My guess is that the PW/PB harness is oil and the PBO is trim.
Any assistance greatly appreciated.
Tack/ Oil Guage
Blu
Bl backlight
B to control unit
G to control unit
Y to control unit
B to control unit
Y to 703
B to 703
G to 703
Trim tilt guage
P to engine
O to engine
B to engine
Y to engine
6H1 Module
y to 703
B to 703
P to 703
GR to Tack red
G
Y to tack B
YR
