Fuel Management System
  • Fuel Management System
    Went to use the boat the other day, all of a sudden my GPH readings are zero no matter what the throttle setting. How do I trouble shoot this? Is there a flow meter somewhere in the system that requires replacement? Thanks in advance for any responses.
    There is a flow sensor thats usually mounted at fuel/water filter, check wiring harness connections to it.
