Sticky Throttle
  • Sticky Throttle
    I recently purchased a 226 Grady White with a 2005 200 HPDI Yamaha. Throttle lever is a little sticky. Anything I can do to make it smoother?
    loosen your throttle friction screw on front of the control box to be sure it's not there. disconnect throttle cable from carbs, then try it to see if the drag is in the cable. If the cable is tight you may be able to lubricate it or may be time for new cable. Good luck!
