ox66 questions
  • ox66 questions
    Where do I attach the tubing from the water pressure gauge on a 97 ox66 ?
    I have looked through manuals as well as all over the engine and cant find the connection any where.
    I also need to run tubing up to the console for the speed tube. what size tubing do I need?
    I am also looking for wiring instructions for the multifuunction tach and speedo but I cant locate any model numbers on either side of the gauges?
    Last question, I am moving my batteries, what gauge and can I get the nice Yamaha conected wiring to replace the existing?
    thanks
    if you look atop the heads you will see a ss plug on each side remove one of those and install a fitting there for the wster pressure guage
      Water pressure port.
      Use like 1/8 tubing for speedo hose. Wire size depends on length of wire probably need 2 gauge.
        Thank you both so much!!
        one more question
        is there a way to adjust the friction on the throttle on a yamaha 703 throttle assembly? mine is so lose if you take your hand off it goes back to idle.
          there is a screw on the frint of the box, this should work for you
