There are several starters for which the first and last part of the serial numbers are variable but the central part are identical (ex: 81800). Can I understand that if the central part is the same, this is an identical starter and that the others numbers identifies, as example, a specific front cover?
If it is correct and if I have such a starter, I have only to buy the correct part for utilizing the starter on another motor.
Thanks!
Thanks!
