I have a 1984 115 that started giving me problems after getting lower unit serviced. Ever since, I get an alarm and go into "limp mode." Sometimes I can throttle back to neutral and start out again with no problems for a minute, but it happens again. I have taken it back to the mechanic, but he can find nothing wrong. I am new to this, so any help would be appreciated!
Over heat problem????
sounds like you need a new mechanic
do you have digital gauges? getting a buzzer? main oil tank on motor full?
if your not getting water up into the power head you need to take that foot back off and make sure that the water tube is seated into the water pump and that there is no obstruction in the pump or tube, also check your thermostats and popets
When I got it serviced they put in new water pump/impeller. So I was told. I am getting pee. I checked t-stats today and found small piece of rubber in one. Maybe that is it. I think it may have something to do with the lower unit being put together wrong.Thanks for responses.
ÂÂÂÂÂÂÂ
