the 4 bolt style tilt trim pump stopped working . upon removal it was found to be full of trim pump oil causing the motor to stop working electrically. any idea whether the shaft seal on the pump or some other seal on the mating surface needs to be replaced. the pump was only used 1 season and was working great till this occurred. any suggestions or was it just a pump shaft failing due to to much internal pressure ? otherwise i'll put the same repaired pump back on it.
trim pump full of trim fluid? 2001 150hp
Probably just a bad seal. The replacement seal is number 35 in this diagram Yamaha Outboard Parts 2001 150TXRZ POWER TRIM & TILT ASSEMBLY 2 Diagram
