switch power heads from f100 to f115?
  • switch power heads from f100 to f115?
    I have a 2000 f100 4 stroke that needs internal motor work done $$$$.
    I have come across a 2000 f115 4 stroke power head that is likely ok but most of the extras outside the block are missing(carbs, intake , electrical harness and more) ect..
    1st, is it possible to switch power heads? remove f100 power head and replace with a f115.
    2nd, would the extras to bolt on the case be the same from f100 to f115?
    in order to get the f115 running.
