Hello.I have a boat that is equiped with a 40 hp 2 stroke gasoline YAMAHA engine.It has always runned perfectly until the last time I ran it.Usually here in Portugal after we use it ( at the sea )we make the engine run in a tank of fresh water. There is a tank for 2 stroke engines and one for 4 stroke engines.I don't know the difference between them.Unfortunatly last time I used it i ran it on the 4stroke tank and now the engine seem to have no force and doesn't have a stable running.It gags all the time.Can you help me? Thank you everyone
Problem!
Start with the basics, check compression, ignition spark, condition of spark plugs, drain gas out of carbs and check for water.
Did you use gas that is usually used for 4 strokes? Cause it does not have oil mixed in it, it will make the engine burn up.
Unless you have an oil injected 2 stroke, that is.
ÂÂÂÂÂÂÂÂÂ
