I have a 2005 50TLRC 2 stroke o/b. The water pump impellar disintegrated over the winter. My question, can I drop the lower unit and simply replace the impeller from the top of the shaft or do I have to remove everything from the bottom up, and are there any tricks or concerns that will jump up and bite me in the butt during this process?
water pump impellar replacement
Here's something I put together a while back. Should help you.
InterMedia Outdoors Forums: Boating: Water Pump Replacement / A DIY Job with Photos
Square Grouper,
I would like very much to see your Yamaha water pump impeller replacement procedure and pictures. I tried the link you provided but it just will not come up on that site. Is there any way you could put it on this site or something so that I could see it? Thanks much.
Originally posted by robert graham View Postgo to: bogueinletnc.com/yamaha for instructions with photos on water pump replacement, plus other procedures. Good Luck!
ÂÂÂÂÂ
