1987 200hp
  • 1987 200hp
    I need help I just bought the boat and the motor runs good except for two problems. 1 It will not start without either the first time. Once it starts it will start all day and run great. 2 it coughs and sputters at a idle. sometime stalls the idle is set at about 800-850 it also smells like its running rich. One more thing if its sits for a week trimmed out of the water oil is in the cowl is that normal?
    Hard to start and coughing usually means low speed circuit in carbs are plugged, need to remove and clean carbs.
    The engine oil tank has a vent hose that connects to air silencer thats bolted to front of carbs, The hose may not be connected and leaking oil into pan.
    If it still has the original oil pump(Keihin) on it, then it needs to replaced(new one is a Mekuni)
      What is so bad about the Keihin pump? I've got them on my 1989s and seem to have no issues.
        The check valves inside oil pump don't hold, when tilted up oil will leak out of oil lines into intake manifold. When engine starts up it will smoke a lot but the big problem is that the oil lines have drained down and it takes a while for oil pump to refill lines therefore engine is not getting oil.
          So far I found one idle jet clogged
            Ok it idles much better no more cough but it still won't start cold. It floods itself
              Any help on the cold start problem. The only way it will start is with starting fluid than it will run all day
                Normally it's extremely hard to flood a Yamaha engine but if it is then check the float heights in carbs, may be set too high.
                  well it seems like its flooded and with a squirt of starting fluid it fires right up. If I choke it it still won't start. also seems to run rich
                    If you have to use some form of starting fluid then it's not choking, check elect choke and choke plates to see if closing all the way
                      They are closing and the manule choke works also
                        You should be able to pull manual choke out, give a little throttle and crank over till starts up. If not check for air leaks in intake manifold, reed valves, leaking crankshaft seals or dirty carbs.
                          OK Thanks.......
                            I had a mechanic (merc. guy) look at it and he said everything looked good and then started to blame it on the ethenol in the fuel. Dose that sound right? I put the blue stuff thats supposed to help it in but nothing has ever changed
