Alarm Sounds Yamaha 60 TLRA
  • Alarm Sounds Yamaha 60 TLRA
    I have a constant alarm sound that comes & gos.
    The water pump discharge does not seem hot to the touch so I don't believe it is an overheat alarm.
    I have moved the fuel tank forward in this river jet boat to balance weight. The tank is approximately 9 feet forward of the motor.
    Is the alarm for "Fuel line restriction" ??
    I had the same problem it ended up being a wire that leaves the control box to operate the gages was shorting out on the aluminum hull
      The water at tell-tale will not become hot even if overheats. If been over 2 years since water pump was replaced, it needs to be replaced. No there is no alarm for fuel restriction just low oil and overheat.
