rigging
  • rigging
    where can get a copy of the rigging or instulation guide for a 2001 250hp ox66., mainly need intial cable adjustment aswell as battery cable hook up at the motors end thanks
    On control box thread cable ends on shift and throttle cables about 8mm and tighten lock nut. Set shift linkage on motor to neutral and control box in neutral then adjust shift cable end to fit pin on shifter. Set throttle linkage on motor to idle position and adjust throttle cable end to fit. Don't have a clear illustration of battery cables.
    The ground cable connects to top of starter housing.
    The positive cable( E in illustration) connects to post inside electrical box.
