Have noticed for a second time Port engine leaking oil. Pulled cover and it appeared to be coming from under the flywheel area because the oil is that far up the engine. Is there a reason this would happen once and I clean and refill and not happen again for 5 more offshore trips out.. Is the seal hard to replace under flywheel? Thanks. Greg
Yamaha 2001 F115 oil leak
oil leak
It could be the crankshaft seal. It is a relatively easy repair. I have had it leak under load and not happen again for a while and I have had it get progressively worse. Pull the top cover, clean up the old oil, run the boat hard and see if it leaks.
Originally posted by bull river cruises View PostIt could be the crankshaft seal. It is a relatively easy repair. I have had it leak under load and not happen again for a while and I have had it get progressively worse. Pull the top cover, clean up the old oil, run the boat hard and see if it leaks.
ÂÂÂÂÂ
