I own a 150 Yamaha, the plugs that are in it are B8HS-10, went to a marina today and they sold me BR8HS-10 saying they the R is for a resistor. They told me if anyone rides in my boat using non R plugs with a heart pacemaker or monitor it could set it off? Is it a crock? Manual says B8HS-10 are the BR8HS-10 new? What should I use.
Ngk Plugs
plugs
I just changed out my old plugs the other day w / the same kind, B8HS-10.
They work fine, stay with the recommended parts.
Check the local auto parts stores...
You can find the NGK B8HS-10 plugs at most any autopart store for $2 or less. The -10 just means they are gapped from the factory at 1mm .
- Mike
ÂÂÂÂÂÂÂÂÂÂ
