2003 yam 50tlrb outboard water pump
  • 2003 yam 50tlrb outboard water pump
    Have a puzzler. 2003 Yamha 50hp outboard, started up engine and it ran a couple of minutes then no water was coming out of head. Replaced water pump and still no water being pumped. I checked for blockages and ther was none. Old propeller and housing /parts seemd OK but still I replaced. Help any ideas.
    BIGE
    The tell-tale hose may be plugged up, remove hose from block and check for blockage.
      I tried that in fact I ran a hose to the connecter tube at pump housing and water came out at tell tale hose
        If you are running on garden hose flusher then put it in the water and try it.
