Gas oil mix through 10 micron filter?
  • Gas oil mix through 10 micron filter?
    I was telling a friend about the need to install a 10 micron filter in his gas line.He premixes the oil into his gas tanks and was wondering if it is ok to run the mix through this filter. Does anyone know if that would cause any problems ?
    Yes you can use it on a premix engine with no problem.
      Thanks for the info. I'll pass it on.
