Hi, I have a 2000 4 stroke 4HP that no longer can go into reverse. We think that the problem is with the shift linkage as forward works fine. Neutral works but is sloppy now and reverse simply cannot engage anymore. A fast ticking/clicking sound is made as it tries to go into reverse. The reverse gear does not engage and neutral doesn't seem as firm anymore.
If you push down the gear linkage in the leg manually the prop locks into reverse gear, but once you let go, it pops back out.
Is this a common problem, and do any experts have any solutions, or does the whole powerhead need to be dismantled to get to the internal gear linkage?
