Motor idles perfect and runs great up to 3200 rpms. Motor will not hold steady rpms from 3200 to 4200. Engine increases rpm without moving throttle forward. From 4200 up I again have normal throttle control. Has identicle issue coming down on rpms. No control from 4200 to 3200.. If I play with the throttle and get it to hold a steady rpm between 3200 and 4200 the motor seems to run rough.
Any help will be much appreciated!
Thank you,
Nick
Thank you,
Nick
