Water pressure gauge instructions
  • Water pressure gauge instructions
    I have a new Yamaha water pressure gauge (6Y7-83660-10-00) it came with no instructions. I was hopeing someone had an instruction sheet that I could get a copy of.
    Thanks Pat
    You will also need the tubing, part number 688-83667-00-00. What motor do you have?
      Ken~It is an F40. I did get the sender kit and gasket from you and I know where it goes on outboard (pretty sure I know how it all goes together) just didn't want to miss something. Just seems if I don't read the instructions I end up with extra parts, thats why I was hoping for some sort of instruction sheet.
      Thanks Pat
        It's simple to install, just connect tubing to water port on engine and run tubing to gauge, connect to gauge. Connect blue and black wires to boat light switch or key switch.
          Thought it looked pretty simple. Just didn't want to miss anything.
          Thanks Pat
