Tilt and Trim
  • Tilt and Trim
    When I let my tilt up it eases back down to the trim in about 25 seconds all by itself. What could be causing this and what do I need to do.
    Check the manual release screw on side of motor bracket, it should tight.
      I checked it and it is tight.
        One or more internal valves or seats are not holding pressure, system probably needs to removed and rebuilt.
          I took it to a marina and they said $1600 to $2200 to fix it. This sounds really high to me. What do you think.
