Can anyone tell me how to turn off the alarm that I get when I shutdown one of my twin Yamaha F150's? I shutdown my Starboard motor due to no water from the tell tale and almost went nuts with the alarm until I got back to the dock.
I had a similar problem.. I was sea trialing and I shut down each motor 1 at a time and the alarm went off when I turned the key back to the on position but instead of shutting down the second motor I dropped down to idle then alarm went off.Dont know if you would have the same results..
Roger
