Having problems with powerlift on an 86-225 yamaha.
I have been having problems trying to lift the motor with the powerlift, i tried adding some hydraulic oil and you can hear that it wants to lift but the prongs don't move:confused. Any ideas on what might be causing it to not lift?
Loosen manual tilt screw on side on bracket, lift motor by hand lock in up position and fill with fluid, release lock and let motor go down, lift motor back up by hand and refill with fluid.
