Transducer
  • Transducer
    Will Mounting 2 Transom Mount Transducer Next To Each Other Cause A Promlem The With The Readings To The Device
    THANKS
    MIKE
    Yes you would only be able to operate one at a time.
      How Could I Use A Fishfinder Gps Combo Unit And A Fishfinder Together
      THANKS
      MIKE
        Probably wouldn't be able to, even if mounted one transducer on bow and other on stern the two cones from transducer's may still intersect.
